221 - 228 of 228 Posts
/) ^3^(\ <- SO AWESOME!!
^^ what can be done to the rsx chassis to gain more traction apart from suspension bushing/better mounts/coilovers/slicks/better alignment??
the traction bars look like they would help the traction but even if the rsx chassis is setup differently then someone should come up with a solution for it no?
There are traction BALLS out there for the RSX and EM2/EP3. Also for the 06+ Civic. Removes play by having a spherical joint in the place of a soft bushing.
Bringing this back up. I have a 2000 civic si, from what I was reading I need to weld a part in order for it to work right? I'm using the eg/dc subframe with a kswap. Is welding still recommend or is that for stock sub frames. I also saw there was three different models you offer now. What is the difference is one better then the other for my build?
