1 - 3 of 3 Posts
K-Tuned Shifter Cable Bushings - Solid
MSRP: $39.99
Applications: 2002-2006 RSX (Except Type R), 2002-2005 Civic SI (EP3),2006-11 Civic Si, 2012-13 Civic Si, 2004-2008 TSX, 2003-2005 Honda Accord
K-Tuned Shifter Cable Bushings are a simple and easy to install upgrade that improves shift feel and accuracy. These bushings are installed on both transmission side connections of the cables and are made with solid 6061 billet aluminum.
OEM shifter cables are made with rubber bushings at the cable ends, which can be responsible for “mushy” or “soft” feeling gear changes. This is because the rubber material can wear out and deteriorate over time. In some cases, failure at these connections can even lead to transmission synchronizer and gear damage. We have even seen damaged shift selector parts on occasion.
The unique dual O-ring design of these billet bushings allows for very slight flexibility at the joint which is critical for precise shifting. Without this movement, binding can occur. Both bushings are clear anodized to protect them from corrosion and we include all hardware needed for installation. With this kit, you’ll get 2 reusable “hairpin style” cotter pins for both cable end connections, and 2 bushing retaining clips.
Or email: [email protected]
1 - 3 of 3 Posts
