1 - 20 of 47 Posts
RSX 3” Oval Tube Exhaust
MSRP: $699.99
Applications: Direct bolt-on for all 02-06 RSX Type-S models but will also fit RSX premium/base models that are using or switching to a Type-S header.
K-Tuned RSX Cat-Back Exhaust Systems have been developed to offer maximum overall performance and excellent fitment, something that until now has been quite difficult to accomplish on the RSX chassis. With several exhaust systems currently available for the RSX, we already know that 3" piping reduces restriction and offers the K engine significant power gains, especially in the higher rpm range. The problem with most RSX exhaust systems has been fitment because standard 3" round piping under the RSX chassis hangs way too close to the ground. This has forced some manufacturers to sacrifice performance by using smaller tubing to compensate for the bad ground clearance. The key feature of the K-Tuned RSX Exhaust System is the unique 3" oval tube mid pipe, which completely solves the ground clearance problem and maximizes exhaust flow. There shouldn't be anymore scraping on driveways or speed bumps because the 3" nominal size oval mid pipe actually hangs at the exact same height as the factory Type-S exhaust.
The system is a direct bolt-on for all 02-06 RSX Type-S models but will also fit RSX premium/base models that are using or switching to a Type-S style header. Note that the entry to the mid pipe has an extremely short section of 2.5" pipe that quickly steps back up to 3". This is necessary because we wanted our system to bolt up perfectly to the stock Type-S header as well as any aftermarket headers that maintain the factory connection point. If you have a turbo setup or an aggressive all motor setup you can easily cut this transition off and join it to your down-pipe or header. The rear section includes a resonator and a fully polished stainless steel muffler with a 4" double wall slash cut tip and we also include all gaskets and hardware. For anyone who has questions about sound, keep in mind that this is an aggressive, race inspired, straight through exhaust system so it will make some noise. This kit was not designed for the average grocery getter RSX.
Or email: [email protected]
Re: K-Tuned 3" Oval Tube Exhaust
waiting for an EM2 version.... hopefully before winter is over with :up:
Been There Done That
damn. if i didn't already have a custom 3" with great ground clearance i'd be all over this.
but, judging by the size of that resonator, it'd probably be louder than mine too. lol
i second this :) CANNOT wait for that!!! such a sick piece.
looks awesome! fingers crossed for an em1 version!
Discussion Starter #14
Hot damn!
K-Tuned releasing some bad ass stuff! :up:
Oval piping :new_slayer:
Thanks Josh. :up:
Will possibly see other chassis? DC2 EG ect?
Looks good!!!
There are alot of exhaust options available for the older EG, DC2 and EK chassis. At this time we aren't planning to make an exhaust for these cars.
will you be making one for da ??? i would love to bolt that to my k tuned ram headers!!!
Sorry man I am doubtful we will make a DA exhaust. There are minimum quantities that need to made and not enough demand.
Order has been placed..cant wait!
Thanks for your order. :up:
will order this next week!
any dyno or estimated power?
There are lots of dynos that show 3" exhausts work very well on the K. Every setup is different so we try to avoid posting power estimates.
Thanks for posting.
As we said in the description this exhaust does make some noise.
This :up: Hope to hear sound clips soon.
I will run this by the boss and see what he has to say about it...
Thanks for posting James, Ryan and Preston. We have discussed making these for the EM2 chassis. However there is no ETA at this time.
:thud:
Well....
James how close is the RSX to fit the EM2? I would have to mod it anyways since my downpipe would need a flange welded on it.
That SHG guy from Hawai'i
I know you need to extend the axleback 2-3" so the tip comes out of the bumper. As for the midpipe, it SHOULD fit as-is, but don't quote me on it.
1 - 20 of 47 Posts
