1 - 20 of 67 Posts
K-Tuned Pre-Fit Heater Hoses
MSRP: $49.99
Applications: EG, DC2, EK (EKK2 mounts only) These only fit with K20A/A2/A3 and Z1 engine or cylinder heads.
Check out our K-Tuned pre-fit silicone heater hose kit. If you plan to keep your heater core, these 4-ply silicone hoses are exactly what you need. Instead of messing around with the oem black hoses, splicing them and trying to make them fit, we have designed a set that is very easy to install. One end is made to fit the smaller heater core side and the other end is made slightly larger to fit the K-series engine side. The hoses are made with a thick high temp rated silicone for excellent reliability. If you want to keep the heater control valve installed, simply splice it in location on the hose leading to the cylinder head and you’re done.
Sold in pairs and made slightly long, they can be trimmed for a perfect fit. You can purchase the hoses alone or with a set of optional worm gear clamps..
Or email: [email protected]
Re: K-Tuned heater hose sets.
I had to loop the block until I found a new hose setup.
Looks like I'm covered.
Question: Can you get the piece that holds the two hoses close together that comes with the other hose kit you sold/see?
Thanks
Here is a set of K-tuned heater hoses mounted on my EK with the heater valve installed. The hoses are very rigid and super clean looking.
We may look into making the handcuff custom because the ones we have are either too big or too small.
Thanks guys. We are always updating things and trying to make them better. I like these hoses better than our old ones as well. :up:
I just picked up a set of these this afternoon. Quality is top notch and they fit perfect.
Will post a couple pics once installed and the bay has been cleaned!
Thanks Mike
Can't wait to get mine. Thanks for the help mike. Half my parts are from K-tuned. K-tuned = good shit.
i ordered some already! thanks mike!:up::up:
does the hose with the valve connected to it have to be cut or does it come as 2 pieces? looks good, will b goin for them so they match my rad hoses :up:
The hoses come in one piece and are sold in pairs. To use them with the heater valve you will need to cut the hose with a nice sharp knife.
1 - 20 of 67 Posts
