1 - 20 of 50 Posts
K-Tuned Now Available At CorSport
K-Tuned has created a series of swap packages that contain everything needed to get your K-swap project completed. With 4 packages available, we have done the work for you, laying out all the parts you’ll need to get your swap done right. From essentials, like mounts, axles, headers and conversion wiring to more detailed parts, like the fuel system, pulley kit and throttle cable kits. It’s all available in one place, K-Tuned.
CorSport USA.
Discussion Starter #14
2002-2005 Honda Civic Si K-Tuned Intake Manifold Gasket
K-Tuned Throttlebody Heatshield Gaskets*
Part # KTG-PRB-MAN (Fits K20A/A2/A3/Z1 PRB Intake Manifolds)
Part # KTG-K24-MAN (Fits K24A2 and K20Z3 Intake Manifolds)
Make a little more power with K-Tuned Intake Manifold and Throttlebody Heatshield Gaskets. Our intake and throttle body heat shield gaskets are manufactured with a high grade temperature insulating plastic. They are precision cut and designed to replace the listed oem gaskets. By insulating the intake and throttle body from the engine heat, it will decrease the intake air temperature, and increase horsepower!*
*So I guess you want to know how they work? The cylinder head gets quite hot when your engine is running. The purpose of these gaskets is to break the transfer of heat between the cylinder head and the intake manifold and throttlebody to create lower incoming air temps. As air heats up, it's density drops, reducing oxygen content, robbing you of power because your ecu has to compensate with less fuel. On average, you lose about 1% of density for every 5 degrees farenheit of increased temp!*
Heatsoak is a thing of the past when you get one of these installed on your motor.**
An added bonus is these gaskets are also re-usable. So you won't have to buy expensive oem Honda gaskets whenever you do some work on your car.
CorSport USA.
Discussion Starter #16
K-Tuned K-Series Fuel Rail & Center Mount Gauge Kit (w/ EFI fittings)
KIT INCLUDES MOUNTING BOLTS AND CENTER MOUNT GAUGE.
ALSO INCLUDES EFI FUEL FITTINGS and IDLE AIR ASSIST VALVE DELETE KIT.
PERFECT SETUP FOR FACTORY K-POWERED CARS.
Applications: Direct bolt-on for all factory K-series cars.
The K-Tuned multi-port fuel rail is by far the best looking rail on the market. Using positive customer feedback and the demand to expand our fuel system parts line-up we have added a center mounted gauge to our popular K-series fuel rail. A two piece fitting uses the existing center port on our rail to properly mount the fuel gauge in the center of our rail just below the K-Tuned logo. The resulting look is very clean, compact and is very easy to install. The fitting is soft mounted on the underside of the rail with o-rings, to eliminate the possibility of dangerous fuel leaks caused by the vibration of the engine unlike other rails where the gauge is hard mounted. The fitting and gauge can be purchased separately or you can get the complete setup with a fuel rail for a discounted package price.
Key Features:
Center mounted fuel pressure gauge
CNC machined 6061 billet aluminum
Fully anodized in black or silver
12.5mm (0.50”) bore diameter
8AN inlet/outlet ports
Supports 1000+ whp
Compatible with stock and aftermarket injectors
RACE PROVEN TO 1000+ WHP
CorSport USA.
Discussion Starter #18
Honda/Acura K20 K-Tuned Billet Oil Dipstick
Applications: Fits all 2002-2013 K-Series engines.
The current trend in Honda builds seems to be somewhat focussed on clean details in the engine bay. With that said, we think most K owners would agree that the OEM orange dipstick on the K engine looks completely out of place, especially on a custom valvecover in a super clean engine bay. The JDM black dipstick is a slight improvement, but the height still has some fitment problems on some chassis. After seeing these unfinished looking dipsticks way too often, we decided it was time to offer something on a higher level to our customers.
The K-Tuned Billet Oil Dipstick was designed to follow the exact contour of the OEM valvecover, giving it a smooth, shaved *look. Along the bottom of front edge is a small flare, which is just enough for removal. Look closer and you'll notice a small hole located at the center of the flared front edge. This can be used to attach a spring tie down on boosted applications where increased crankcase pressures can blow out the dipstick.
Starting with the 6061 billet aluminum top, our signature K logo is engraved after anodizing. All the remaining parts are 100% stainless steel, including the base, wire and level indicator. The base seals properly with 2 o-rings just like OEM and the level indicator has 2 markings on it, again matching OEM. Available for both K20 and K24 engines in 5 colors plus raw aluminum for those who might be interested in polishing or a custom color match.*
CorSport USA.
Discussion Starter #20
02-06 Acura RSX K-Tuned OEM Shifter Cables and Bushings
Shifter cables have been a high demand part in the K-Series community for a few years now. *If you are putting together a K-swapped car and didn’t get the shifter cable set with your engine, you can either try to find them used or get them brand new from a local Honda/Acura dealer. *The problem with the dealership is they can be expensive and occasionally they are on backorder which means there is a wait time to get them in hand. *K-Tuned OEM-Spec / Street Shifter Cables are a strong and cost effective replacement for all OEM 2002-2006 RSX cables. *Fitment and overall length is identical to OEM which makes them compatible with all OEM and K-Tuned shifter boxes, as well as many other aftermarket shifter box options.*
These OEM-Spec Shifter Cables are made entirely of high quality materials and they were designed to meet or exceed the OEM units in all areas of construction. *The transmission side of the cables features our 6061 billet aluminum shifter bushings at both connections. *The unique design of these bushings allows for slight flexibility at the joint which is critical for precise shifting. *These bushings improve shift feel and accuracy when compared to the factory rubber bushings. *We also offer our Billet Shifter Cable Bushings separately for anyone that already has OEM cables and may want to upgrade. *Our cable set is sold complete with all hardware for installation. *This includes 4 reusable “hairpin style” cotter pins for all cable end connections, and 3 cable retaining clips. *Note that 1 of the connections uses a self-locking setup on the shifter side. *Our OEM-Spec Shifter Cables are priced right, made to last and work flawlessly. *Race car owners may also want to check out our K-Tuned Race-Spec Shifter Cables, they are the best shifter cables available for your K-Series powered car.
Applications: 2002-2006 RSX (All models), K-swapped EF, EG, EK, DC2
CorSport USA.
1 - 20 of 50 Posts
