1 - 4 of 4 Posts
K-Tuned OEM-Spec/Street Shifter Cables
MSRP: $279.99
Applications: 2002-2006 RSX (All models), K-swapped EF, EG, EK, DC2
Shifter cables have been a high demand part in the K-Series community for a few years now. If you are putting together a K-swapped car and didn’t get the shifter cable set with your engine, you can either try to find them used or get them brand new from a local Honda/Acura dealer. The problem with the dealership is they can be expensive and occasionally they are on backorder which means there is a wait time to get them in hand. K-Tuned OEM-Spec / Street Shifter Cables are a strong and cost effective replacement for all OEM 2002-2006 RSX cables. Fitment and overall length is identical to OEM which makes them compatible with all OEM and K-Tuned shifter boxes, as well as many other aftermarket shifter box options.
These OEM-Spec Shifter Cables are made entirely of high quality materials and they were designed to meet or exceed the OEM units in all areas of construction. The transmission side of the cables features our 6061 billet aluminum shifter bushings at both connections. The unique design of these bushings allows for slight flexibility at the joint which is critical for precise shifting. These bushings improve shift feel and accuracy when compared to the factory rubber bushings. We also offer our Billet Shifter Cable Bushings separately for anyone that already has OEM cables and may want to upgrade. Our cable set is sold complete with all hardware for installation. This includes 4 reusable “hairpin style” cotter pins for all cable end connections, and 3 cable retaining clips. Note that 1 of the connections uses a self-locking setup on the shifter side. Our OEM-Spec Shifter Cables are priced right, made to last and work flawlessly. Race car owners may also want to check out our K-Tuned Race-Spec Shifter Cables, they are the best shifter cables available for your K-Series powered car.
Or email: [email protected]
1 - 4 of 4 Posts
