21 - 40 of 47 Posts
Discussion Starter #21
I am not sure why you went through all the trouble of wiring up the ignition switch when these bypass boxes are available. However, performance wise, the stock ecu setup can be disappointing. These boxes are good to get the car running, but if you want the car to perform really well you should consider getting KPro. I guarantee you'll be happy with the results afterward.
I am about to put a k20z1 swap in a 1989 crx si will still be able to use my stock ecu and just get the jumper harness from the ecu to the interior?
does this eliminate the use of the secondary O2 sensor? i recently ordered one off ebay and now that i'm awaiting it, i just began wondering if i will still have to use the secondary O2 sensor.
21 - 40 of 47 Posts
