1 - 20 of 47 Posts
K-Tuned Immobilizer / Multiplexor Bypass
MSRP: $199.99
Applications: Works with 2001-2004 K&D ecus - PLM, PLR, PND, PNF, PRA, PRB & PPA
The K-Tuned Immobilizer / Multiplexor Bypass unit is designed to allow the use of a stock K-series ecu in a swap application. This affordable option is very easy to install and disables both the immobilizer and the factory multiplexor system. This is a great alternative to other systems, which cost substantially more money. One more part that is making a K-swap a little more affordable.
Installation Notes: Four wire installation, comes with two T-tap connectors for power and ground. The other two wires come with stock ecu pins in place for a quick installation once the un-used stock wires are removed.
Or email: [email protected]
Discussion Starter #5
Re: K-Tuned Immobilizer NOW IN STOCK!
Yes it will work with the same ecu's as other similar units. PM me if you want to confirm your ecu application.
02 type s engine, trans, harness and ecu in 99 ek. hardwired in rsx ignition and key to have functional immobilizer. but still have multiplexor code. car doesnt feel fast ,single cams keep up with it
1 - 20 of 47 Posts
