1 - 20 of 43 Posts
K-Tuned Front Stabilizer Bars for 88-91 Civic / CRX
MSRP: $169.99
Applications: 88-91 EF Civic / CRX and 90-93 DA Integra. Designed to work with all K-Tuned / ETD Traction bars.
NOTE: Will NOT fit with front sway bars.
Here is another innovation from K-Tuned. These additional stabilizers are what hard-core racers with 88-91 Civic / CRX and 90-93 Integra race cars have been asking for. These additional support bars are mounted from the back of the front LCA to the floor frame rail. The kit uses one existing bolt hole found on the oem subframe, the other bolt location needs to be drilled through the floor frame rail and bolted up. They are designed for use with 88-91 and 90-93 K-Tuned / ETD traction bars.
Or email: [email protected]
nice setup
What are you guys making for the EG? If i'm not mistaken the setup for the EF/CRX basically makes the lower control arm in to a wishbone or A arm style control arm?
With more than one point mounting to the chassis it should be more solidly mounted and create less deflection... The traction bars do the same thing from what I understand but adding a thrid mounting point.
With the EG, DC, or Ek chassis they already have a double wihsbone front suspension setup. So are you looking at adding a 3rd pickup point for the lower control arm not counting the traction bars, with the traction bars being the fourth?
Discussion Starter · #10 · (Edited)
We are planning to make a kit that replaces the heavy oem front LCA with an Aluminum bar and rod end setup. It will basically convert the front LCA setup to the 8891 style with a traction bar and stabilizers.
It will be designed and recommended for occasionally driven cars and more so race cars. Daily driven cars may want to keep the oem LCA in place for drive-ability.
So the whole front LCA will be aluminum bar? Sounds interesting...
Discussion Starter · #12 ·
The front LCA on an EG/DC2/EK is a two piece design, a main bar and a bolt-on rear section. We will be designing a rod end setup to replace the rear section only. Sorry, I should have made that more clear when I first posted about it...
Ok gotcha...
You guys going to incorperate any type of sway bar mounting point on them?
Just to be accurate the EK ones are all 2 piece except the SI. The SI is a one piece and the sway bar mounting points on all the other models are located on the rear piece you are reffering to replacing...
HONDA HEAVEN RIP
this should eliminate the noises coming from the fronts of ef's when using aftermarket bars?
p.s. you should loosen that inner boot on the driver side axle and then re clamp it. :silly:
Discussion Starter · #19 ·
The light noises are due to the front end being mounted partially solid. Adding these bars will make the fornt even more solid and divide the stress. I'm not sure how it will affect the noise...
Thanks for the heads up on the axle. :silly:
1 - 20 of 43 Posts
