1 - 4 of 4 Posts
What’s up everyone! I recently got my k24a started in my 99 civic ex. It ran for a day once I uploaded my base map on kpro. It sat for a few days and no it cranks but won’t start. Things I’ve checked
-grounds (all good)
-crank shaft position sensor was replaced
-fuel pump works
I’m not getting any spark, I’ve replaced the coil packs three times (I have three sets that are known to be good) The car has a brand new battery since it’s been sitting for 5 years. Every fuse and relay has been gone through as well. I’m lost, any help or information would be greatly appreciated! Thanks for your time
Is your fuel pump priming? Do you have fuel pressure? Does the kpro register rpm when you crank the engine? Are you logging any faults on kpro?
Cranking has nothing to do with the ECU. It cranks even with the ECU removed.
I assume you have lost power or ign on signal to the ECU.
Otherwise it would prime the fuel pump.
Easiest is first to log into the KPro with a laptop with ignition on and see if you get a connect.
if not, we go from there.
you've probably checked but do you have the immobilizer unchecked in the tune...? I got an etune back and it was changed. it stumped me for a bit.
1 - 4 of 4 Posts
