non vtec said:
If your really clever you can turn the housing on the block around so you can run the radiator on the original side and put your filter in the front bumper..
All you need to do is file a peice of the housing and turn it 120' so it points downwards and you'll be fine... You wont have any issues with the way the car runs, since I ran my car that way for about 6 months before I mounted my ITB's
Never thought of that either...but good stuff!
If you do relocate the radiator to the driver's side,I know the upper radiator hose from the rsx will work perfect,but Ive never tried the OE Rsx lower radiator hose,as Ive always had bits and pieces of spare hose that ive trimmed to fit.For the bottom,You'll need a straight,12" hose with a 90 degree bend at the end with another few inches of hose after the bend,and trom to fit from there.
If you run the radiator at the OE placement,you'll need an extension pipe and some spare mix and match pieces of hose.The bottom hose should be able to use any 8" section of hose,trimmed to fit.
For the Heater hose and brake booster hose,you'll just want to make a trip to the auto parts store and by a few feet of heater hose and a few feet of vacuum hose and trim to fit.
