1 - 16 of 16 Posts
now that the ref is back open i'm interested in ref'ing a K in my 94 si and i was wondering (i searched but nothing new since 07) if anyone has information on this and what is needed.
so far i have got:
need to have all emission sensors
cat
stock exhaust
stock ecu
I heard that you had to use a rsx tank, having something to do with the purge valve.
Discussion Starter #4
whats wrong with using the fuel pump with the fpr in it? does it not fit in the eg tank?
is it the tank or having to be returnless style?
I'm trying to do the same thing with my eg right now. Yes r-crew did it already they used everything k ( fuel tank, under dash harness, dash and gauge cluster ) If u move to texas isn't there smog laws different. The main problem i'm having with my swap is the ecu isn't getting constant power ( i need to change some wiring ) Good luck
1 - 16 of 16 Posts
