is it posible to just use the rsx axles and change the outer boot to the integras? or you just gota use custom axles from hasport and places like that. i know there is no oem that will fit. and the integras are shorter.
which ones because i have snapped the stage 1s and 2s. running on 24in slicks. i hear stock are holding up best.TeamPacman said:GET THE HASPORT AND YOU ARE DONE :wink:
Realy..??allmtrallday said:which ones because i have snapped the stage 1s and 2s. running on 24in slicks. i hear stock are holding up best.TeamPacman said:GET THE HASPORT AND YOU ARE DONE :wink:
yeah bro they snapped, your buddy was at bakersfield, i talked to him, real cool guy, he watched me snap right at the line. that was with the 400hp ones. and trust me i would go with the stage 5s if i had the money. but damn 1200-1300. :shock:TeamPacman said:Realy..??allmtrallday said:which ones because i have snapped the stage 1s and 2s. running on 24in slicks. i hear stock are holding up best.TeamPacman said:GET THE HASPORT AND YOU ARE DONE :wink:
Hmm Try the stage 4..
Must have to much POWER :wink:
yeah there are some more races early january, im going to try some oem axles. we'll have to see how it goes.non vtec said:How much power do you think your making????
Do you have traction bars, solid mounts, and whats the car weigh...
If you have to many problems try stock honda axles...
Mine have never had any issues..
allmtrallday said:yeah there are some more races early january, im going to try some oem axles. we'll have to see how it goes.non vtec said:How much power do you think your making????
are ProFab axles made using OEM parts???? who is running them here? any problems???dapretendr said:is it posible to just use the rsx axles and change the outer boot to the integras? or you just gota use custom axles from hasport and places like that. i know there is no oem that will fit. and the integras are shorter.
yeah thats what hasport told me too. hopefully i wont break next time at the track. im launching at like 7500rpm, i dont know if it spins because they break, i was running 23 in slicks, and the 200hp(stage1) axles were fine, then move up to 24.5 inch slicks, with drag springs and havent got to make a pass yet. hopefully the heat treat thing is true, makes me feel sick to think i paid 650 bucks for some axles that cant handle half the power they are rated for. :?adirondackR said:are ProFab axles made using OEM parts???? who is running them here? any problems???dapretendr said:is it posible to just use the rsx axles and change the outer boot to the integras? or you just gota use custom axles from hasport and places like that. i know there is no oem that will fit. and the integras are shorter.
I heard the axles breaking (were made by DSS) - were breaking due to a problem with a heat treatment process....I believe this should be solved by now <--- I am NOT 100% sure - I think the experts should speak up on this one
