1 - 20 of 33 Posts
Package Starting At $549.00 Shipped
Exedy Organic Stage I Clutch
EXEDY Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of our clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
Exedy Cerametallic Stage II Clutch
EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. The cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading.
ACT - XACT StreetLite Flywheel (11.4lbs)
* Lighter and stronger than a stock flywheel
* Better driveability and durability
* Super rigid, precision made, and dynamically balanced
* Recommended for daily driving, street and drag racing
ACT - XACT ProLite Flywheel (8.4lbs)
* Lightest XACT flywheel
* Best throttle response, lowest inertia
* Recommended for street, drag, road and rally racing
CorSport USA.
Discussion Starter #10
K-Series Exedy Clutch/Flywheel Package
K-Series Exedy Clutch and Flywheel Package
All EXEDY cerametallic clutch discs have spring center dampers to reduce the impact and shock loads put into the drivetrain. This protects the transmission and the rest of the drive line system.
With any cerametalic clutch system, there will be some compromise of start up driveability as compared to a stock clutch (chatter on light throttle, low rpm start up). This characteristic is general felt to be acceptable in modified performance cars. Drivers of cerametallic clutches on the street should be warned not to "ride the clutch" to try to reduce the chatter as this will greatly increase the wear.
Exedy 9LB Lightweight Flywheel
Exedy Racing Flywheels are made from solid one-piece billet chrome moly steel or chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibilities of separating from the flywheel. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). EXEDY steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at the said rpm.
For but not limited to the following applications : K20A2,K20A3,K20Z1,K24A2,K24A4,K20Z3
CorSport USA.
1 - 20 of 33 Posts
