1 - 12 of 12 Posts
basically the TSX throttle by wire TB has to be removed, and replaced with a TB that is driven by throttle cable instead.
the K-pro is designed for manual throttle cable TBs only, therefore it will not work with the stock TSX setup.
litterbox said:
So you just swap it out for a type s TB huh. k.
Not quite, because the type s throttle body is not a direct bolt up to the TSX intake manifold. You can swap the intake manifold, or there was a vendor on here that makes an adaptor plate, but I can't remember who it was. You can also get a Euro accord throttle body and I think it bolts up.
1 - 12 of 12 Posts
