1 - 1 of 1 Posts
a few questions. Ive talked to hondata a few times, i just wanted to see what other users are having happen.
my K-pro keeps losing connectivity to the ECU while driving,
the engine is limited to aroud 3k rpm, the ECU cuts fuel to the injectors at about 3k or so
i have an ECT high voltage error code and IACV error code ( i dont have an IACV installed)
most everyhting else seems to be operating properly, i have NGK IR Iridium resistored plugs heat range 6 it looks like
the car idles ok, then sometimes it doesnt, hunting up and down like a b-series with a bad cold start valve does. much much faster hunting though almost like a rev limiter.
lemme know what if anyone else has had problems
im posting this into the swap section too its in an EG
1 - 1 of 1 Posts
