A stock K20 is good for 165 whp. What do you want to know specifically?@LotusElise i was watching a cam swap comparison video from the Tegiwa and was wondering if you could elaborate on this type of dyno reading ? Is this normal for a k20a2 to make low 200whp overseas ?
BTW, the correction factor calculation isn't correct for the rated conditions. It should be according DIN Norm 70020 Qv = 0.981 [-]. So the results should be even lower, because of the cold air temperature. Standard temperature is higher it is 20 °C 🧐...so enough teacher talk here 😄.
