can i use the jdm underhood wire harness, on an EK swap? i have been told the jdm one will not work, in which case i have a wire harness from a USDM base rsx, will this one work, or am i confined to using the USDM rsx wire harness.
thanx!
thanx!
^typer0186 said:i heard if u use a jdm harness u have to mount the ecu on the driver side but if u use a rsx one u can mount the ecu on the passenger side.
