1 - 15 of 15 Posts
i have a jdm type r(prc) ecu with hondata in it... for some reason no fuel pressure is coming on.. it dont turn my car on but wen i plug my friends hondata in it starts right up.. he has a usdm type s with hondata.. any help plz?
(EDIT):: i forgot to mention my car is a eg hatchback.. and im using a hybridracing conversion harness
Super Moderator
Does his ECU start your car or did you not try that yet?
GoldStar
just for clarification, your fuel pump is not priming when you key your car on using a prc ecu? if so, are you using e1 on your e-plug for fuel? e1 wont work for a prc. you have to use either e10 or e15. try it out you'll see.
What chassis?
I know with the EP3/DC5 chassis the PRC ecu doesnt have any immobilizor feature so the chassis wiring has to be modified to turn on the fuel pump.
Discussion Starter #7
i dont have an E plug.. lol.. but yes wen i put the key foward no fuel is coming on at all.. the onli wires i tapped into was fuel pump.. check engine light.. chargin and eld.. it works fine with the usdm type s ecu with hondata..
GoldStar
If indeed you have a k-series motor in your car and are indeed using a k-series ecu then, YES, you DO have an E-plug. There is an A-plug (31 pin), a B-plug (24 pin), D-plug (17 pin), and an E-plug (31 pin) which all plug into the ECU. The E-plug is on the end.
The wire you "taped" for the fuel pump is most likely the "E-1" pin in the E-plug. For a PRC ECU the pin for fuel pump is E-10 (right below E-1 pin) on the E-plug. That is probably why your PRC ECU is not causing the fuel pump to prime when you key the car on.
02-05 JDM Integra Type R DC5 -- ECU: PRC (without Immo.)
05+ JDM Integra Type R DC5(new shape facelift model) ---ECU :pRC(with IMMO.)
So 05-06 JDM DC5R equipped with immobilizor.(Facelift Models) even PRC.
Also 05-06 JDM Civic Type R ECU`s (PRB) equipped with immolizor.(facelift model)
I dont know what about 06+ Civic Type R FD2 ECU .. but %90 it has immo.
Discussion Starter #11
Good point Fuat. What I stated above applies to 02-04 PRC ECUs. If he has a PRC with Kpro its more than likely is a 02-04 model.
thanks for the help guys..
1 - 15 of 15 Posts
