1 - 7 of 7 Posts
Hello,
  • Im completing a kswap on my ek civic. I sourced parts from ktuned and for some reason the ep3 pulley kit that came with it doesnt seem to fit. I am using a jdm k24a. Pictures are below, and any help will be highly appreciated
From what car can i get that from, and is that the only thing i need to replace? I live a Bit far from auto shops so i just wanna go in one time and purchase everything i need.
Thank you!
hello, i had the same problem when using my jdm engine. Even the idler hit the hasport motor mount that i was using. I just went to the junkyard and got a serpentine set from an accord. that includes the power steerign pump, idler and alternator. basically everything.
I ran into a similar issue as well. I tried to use a EP3 idler pulley and nothing lined up... What I end up doing was I grab all the accessories off of an RSX Type S to make it work. This also gave me the ability to have the OEM oil cooler as well. I hope this information helps.
I am dealing with this on a JDM K24a swap as well. What I have learned from speaking to KTuned, HASport and others who have got around it was to do the following so I can use the K Tuned AC/PS delete with alternator relocation kit.
Got a Base RSX alternator and a CRV water pump housing. I was told the housing can also come from the RSX, TSX, and K24 Accord.
1 - 7 of 7 Posts
