121 - 137 of 137 Posts
Discussion Starter · #121 ·
I asked before if the ITR boot would fit over the adjustable part of my HR shifter. I recently picked up a stock EJ1 shift boot that fits nicely over this assembly. It stretches a little snug in 2nd gear (longest throw of the shift assy), but nothing im too worried about. Knowing this, would this change the opinion on the ITR boot fitment?
These ITR ones are the same size as the EJ1 boot, so that will work, I also have EK9 boots instock which are a bit taller which give more room for the shifter, you would have to reuse your stock bracket if you use the EK9 boot
So this is a direct replacement for the '06-11 Si shift boot correct? How much to have one shipped to Ontario, Canada(L1M 2H6). Thanks.
Never mind, I actually did some reading. As you were.
