Issue:
Engine will idle for 30+ minutes, no problem.
If I drive the car, I can get maybe 15-20mins of run time before the car begins to hesitate at part throttle. Will stall coming to a stop. Won't start back up for ~30 minutes. If I let it cool down completely, works like nothing happened for another 15-20mins.
Datalogging shows nothing that would point to any kind of issue.
What was checked:
What else could it possibly be? Why would the engine not want to stay running after being driven, but work without issue idling?
What was checked:
- Fuel pump replaced
- verified getting correct fuel pressure (55psi)
- New coilpacks, verified spark when engine won't restart.
- Wideband replaced
- Cleaned injectors and verified injectors were working when engine won't start
- Swapped relays around to see if car would start, nothing.
- Checked Crank sensor for voltage and 5v, both pass. Replacing sensor soon.
- Swapped maps, nothing
- Disabled Closed Loop, running in Open Loop, helped for a little, then would still fail.
