Are you sure about that? I believe the K24 Crank pulley is actually larger than the K20...brian g said:The diameter is the same and they will interchange.
brian g
My bad, for some reason I read K20A3 not K20A2.TurboRSX-S said:Are you sure about that? I believe the K24 Crank pulley is actually larger than the K20...
