1 - 3 of 3 Posts
I was wondering if the CRV Block Bracket (PN 11910-PPA-000) is required for a K24a2 swap into a EK civic? I looked thru the K tuned swap packages, and even their level 4 package does not have this. So I was wondering if i need it for the swap? Also on Vtec academy, it says i can reuse 2 of the existing bolts, but will need an extra 85mm bolt for another hole, does anyone know where i can acquire a 85mm automotive bolt? It does not seem like orileys or autozone sells them
Thank you
You would need that bracket for a K24a2 in an EK. If you use the OEM one (the part number you’ve already listed) and you’re looking for the 85mm bolt, here is a link to an OEM Honda parts store online.
It’ll cost more in a dealership local to you but at least you’ll have that bolt.
As far as aftermarket, KTuned and I believed P2R sells a billet bracket for that position, but it costs more. I know for sure the KTuned one comes with its own bolts as I’ve used it before. I personally use the OEM bracket
1 - 3 of 3 Posts
