1 - 3 of 3 Posts
so my setup is k20a2 head z1 block with stock prb ecu w/ktuned immobolizer so was running fine then all of a sudden wont rev past 2k so i changed out stock a2 harness for mil spec tucked but now i dont noe wat the green white and black wires are?
don’t know, but not reving past 2k is likely caused by a missing TPS signal.
Did you record a data log before swapping harnesses?
These aftermarket harness have grlund wires that differ from OEM. Best to call tucked.
96 civic HX K24a
If you could post pictures of the wires that would help. I would keep your oem harness around just in case. Did it have any cel before you swapped them and what brand harness is it ?
1 - 3 of 3 Posts
