1 - 4 of 4 Posts
I have a K20A2 swap in my EM2 and I am using 4 lug setup front and back,
what are the benefits and is it worth doing all the work?
Thanks in advance on your input.
If you start snapping axles then maybe it would be advisable to go 5 lug but I think that would be more of “if you feel like it “ than a necessary conversion. Are the em2 like base model rsx with 32mm axles ?
Discussion Starter #4
Yes, and is apart right now as i am adding Turbo and adding upgrades to the engine.
So to do the switch what parts do i switch to is it just all rsx type s parts, lower control arm, rsx type s axles, spindle knuckle hub and same for the back end?
Also who makes good axles we will be pushing 600 Plus HP on this setup.
1 - 4 of 4 Posts
