welcome to the forum and thank you for registering.
how can it be proved that it has 60,000 miles on the engine? you really cannot prove that, just have to take their word.
not trying to be rude, are you mechanically inclined? can you check over the engine before actually exchanging money?
example, can you do a compression test? pull the valve cover inspect the timing chain, cams, valvetrain, spark plugs?
Installing a header, exhaust etc. is easy and easy to build. The big question is did the previous owner skip steps, forget something (we all do that from time to time or some do it really bad), do they have a service manual?
not trying to be rude, are you mechanically inclined? can you check over the engine before actually exchanging?
Thank you and yah you are right, I can’t prove the miles. And I am not a mechanic and haven’t ever done a swap, just filters, chains, belts, plugs, and injectors (the basic stuff) but I’ve been learning about k swaps for a couple months now and I think I could do most of it.
And yah I like what you said about checking the stuff first, I’ll make sure to do those, compression test, chains, etc. Is there any common problems with that engine or parts that I should look out for?
And I plan on going through the steps of the swap to see if and where he skipped anything or did anything wrong.
Thanks again for your reply, I’ll make sure to check those things.
