1 - 20 of 36 Posts
hey guys, was jus wondering if anyone is running the ips-k2 cams on a stock motor with bolt-ons? looking into cams and wanted to know if they are "streetable", like are they extremly lobey or if they bogg alot under light throttle? was readin up on their website but wanted to get some real expierience info thanks
Yes, they are streetable on a stock motor. Even on a 13.5 comp k24 they idle great.
how much more power did you make over the stock cams with the ips k2 cams.
hard to answer that question since different bolt ons were used. the gains were significant.
i'm really curious about these cams too. I have a type -r motor and was wondering what the gains would be in the type r motor. if the gains would be significant.
u should be able to gain a minimum of 10whp with those cams, up to about 20whp, on a stock bottom motor... results may vary
Sorry to slightly jack the thread but saw no reason to start another thread.
Do the K2 mk III's give much more power over the other K2's? I'm looking at them because of their aparant 'nitrous ready' status but was wondering if there was any advantages?
The Mark III's are really designed for an all out fully prepped kind of motor...
from What I understand
They would be a great choice for a cammed, high revving, high compression, ported head type of setup.
They may still work OK for a more street type of setup, but thats not what they were designed for... Not sure what your plans are but the Mark II's may be a better choice
Planning to give a head a port and polish, supertech valve train. K24 Bottom end with a 2.6Ltr stroker kit, but probably only 12:5:1 compression, S2000 oil pump, etc, etc.
Pretty much a a fully built motor, definatly not a Daily driver. More of a weekend cruiser/strip racer.
Do the Mk III's only make power top end? I definately wouldn't want something that only made power from 6000rpm or something like that.
You want a different cam, the K2 profiles are suited for motors around the 2.0 L displacement.
Any recomendations?
I was mainly drawn to the MK III because they were "nitrous ready" however I realize that might not mean alot because you're cams don't really suffer when spraying, Its mainly the rods and pistons I'll need to worry about.
I don't really mind If cams are really lumpy as long as they have a good midrange powerband. Otherwise It'll be just like my torqless B18C that doesn't move below 4000rpm :(
GREEK IPS SOLDIER
Agreed pal....:up:
Just for the record,my ep3 with k2's,rbc IM,hytech hdr and stock block,delivered 235whp dynapack!
Any recomendations?
With the displacement you plan on having power before 4000 will not be a problem, even if you used stock cams.
I would get a set of KVX's.
Agreed :up:
Thanks guys! :D Will look into these KVX's need to research them a bit. (which is hard when the search engine wont include words unless they are atleast four letters long :silly: )
Here is a build Nikos is doin with the KXV's and a stroker kit similar to what you were talking about... he should have numbers soon
Hey people i like a put cames ips k2 mark2 in my k20a2.i have my block stock and my question is,i now i need springs and retains supertech ,but i don´t now if i need pump oil,head gasket or anything more i don´t want my k20a2 make pummmm
need help please
1 - 20 of 36 Posts
