I got bored tonight so i started to compare part numbers..... after i was checking out some specs while tearing down my TSX engine for the build....
check the part numbers on different years for the conclusion.
15830-PNC-003 VALVE ASSY., VTC OIL CONTROL 1 2004 Acura RSX 96.33 77.06 (2002-2004)
15830-RBB-003 VALVE ASSY., VTC OIL CONTROL 1 2004 Acura TSX 94.45 75.56 (2004+)
15830-RBB-003 VALVE ASSY., VTC OIL CONTROL 1 2005 Acura RSX 94.45 75.56 (2005+)
Seems the VTC from the RSX-S 2005 is the same as the TSX, meaning the oil pressure would be provided to rotate the cams to 50, not only 25.
another interesting fact.
14620-PNA-020 ARM ASSY., ROCKER 8 2004 Acura RSX 242.58 194.06
14620-PNA-030 ARM ASSY., ROCKER 8 2005 Acura RSX 242.58 194.06
14620-PNA-020 ARM ASSY., ROCKER 8 2004 Acura TSX 242.58 194.06
14620-PNA-030 ARM ASSY., ROCKER 8 2005 Acura TSX 242.58 194.06
a company has mentioned the rocker arm ratio was 1.75 on the intake and 1.74 on the exaust but.... why is the rockers directly reversable, and the ratio is off. the sliders and everything is a dead mirror. (hmm... )
the rocker arms are the same all true vtec style, the very interesting part is, that the shafts on the A3's can have the valve train components of the A2 series, however no lost mostion assembly holes. and minus the exaust oil holes for the rocker assembly vtec feed.
i'll know everything else in a few days, the build is allready underweigh. mesuring specs have allready begun, claying will be soon done on the new Cores.
Should be fairly interesing new few days.
