1 - 8 of 8 Posts
k so has n e 1 ever seen a intake valve get jammed in the head?? i started taken apart my k20 nd i see as broken valve in the port. nd i have seen pletty of blown motors but never 1 where the intake valve is inside the head....
am i screwed???
if so n e 1 got a k20a2 head i can buy pls........
I seen them before like that. Over rev, valve hits piston, valve bends then brakes and the piston pushes the valve in the head side ways.
pictures? might be fixable
Discussion Starter · #7 ·
i would take pics but i cant get the head off cuz the main pully bolt wont come out of the crank... but i can see threw the intake ports nd see the valve, also if i get it fixed, as in welded, would it still be safe to push 500+ hp without me worrying about it breaking????
if you can't get the head off you don't have to worry about pushing 500+hp out of it...
You need to show what kind of damage you are really looking at before anyone can give you a solid answer about fixing it...
1 - 8 of 8 Posts
