1 - 2 of 2 Posts
hey buddy, clutch is about a 5 on the sclae of diffculty:
remove intake and remove cotter pins conecting the two cables to the stick, unbolt the mount for the cables
remove the bolts securing the clutch line (once this is done DO NOT push in the clutch) the thing does pop out, but you can press it back into the slave cylinder by hand no biggie
jack up car as far as axle stands will allow
remove rims
carefully unbolt the knuckle from the shocks, careful the axles may separate at the cv, but don't sweat it, its realy easy to pop them back in
take off the spindle nut (after taking out the divit into the axle with a screwdriver)
yank the driver side axle out
remove the half shaft cover and moutning bolts than yank out the passanger axle (will require a prybar)
then put the jack beneath the motor (not the tranny)
procced to lossen the engine mounts on the subframe
drop the subframe
remove tranny (this can be a bitch)
you will need a 12 point ratchet set to remove the flywheel
replace the clutch (make sure to buy an alignment tool)
buy a new throw out bearing from the dealer
now for the hardest part, to get the tranny back on, you have to kick the shit out of it and wiggle it a lot to get the shaft on there, and then to seal the deal. I personally got it in about an inceh away, and then started toquing the bolts, don;t go crazy though, don;t want to strip any threads
not, slap the axles back in after coating the tips in oil, blah blah blah, if yuo need the manual send me a pm, and I''' email it to you.
btw: I replace spindle nuts after pulling the axles twice, may want to do it for shits and giggles now
best!
p.s. hit me up if you get an lsd, that it a bit more complicated!
1 - 2 of 2 Posts
