1 - 3 of 3 Posts
hey guys i intrested for ep3 turbo stock engine but here in australia it's k20a jdm engine and have more compression than k20a2 my friend have one k20a2 on stock engine turbo 500+ can it be the same on k20a jdm on stock engine thank you guys :)))
It is hard to say. It depends on the current condition of the piston rings. Once a compression test has been performed, then a decision can be made how much boost you can safely put on the K20a-R (11.5 comp.) engine. From what I have read a healthy used K20a-R engine can handle low boost levels reliably - maybe 12-14 psi.
A leak down test would also help out as far as evaluating the engines health. 11.5 is pretty high compression so I would take it to a reputable tuner if you do put a turbo on it, but it’s been done many times before.
1 - 3 of 3 Posts
