dont worry about that , i had run my b18c5 with upgraded piston domed, i was at 11:5.1 and i run my turbo at 7-10 psi dosnt blow, always reflect on your tuning, the guys who tune the car he have the magic touch in his hand.But for sure its more riskyitsrsxxxrated said:yup I wanna upgrade the Injectors to a higher cc and 9lb pulley..but i dont wanna blow my engine w/ my compression. is it ok to run 9psi on a 11:5:1 compression engine with stock internals?
It wouldn't hurt to drop the compression a little bit, but if it is tuned well it really isn't a problem. The tuning is where the risk really comes in to play. if you run 9psi on an untuned 11-1 or 12-1 whatever it is you are asking for trouble. But if you get it tuned by an experienced tuner you will be fine at that compression with that kind of boost. Although from what I have always read about the JRSC kits they are effected by heat soak, the supercharger just gets to hot after any period of time and the air it is compressing starts to ubsorb heat from the supercharger therefor not producing as effectively as if you where pushing colder air. I would look in to a way to cool down that air befor you look to up the boost. but I wouldn't be to concerned with the compression at this point.itsrsxxxrated said:Well my Pistons arnt upgraded. I was thinking maybe a Thick Head Gasket? To bring my Compression down a bit.
How do I cool down the Air? They dont make a Intercooler or Aftercooler for this car..I have a AEM CAI in the Fender?..jon v said:I would look in to a way to cool down that air befor you look to up the boost. but I wouldn't be to concerned with the compression at this point.
What kind of ECU are you running?
U mean the Air Intake Temp? I have a AEM CAI..Hondata makes a Heatsheild that helpsBolivianFuego said:You;d be ok upping The boost but the thing thats dangerous isnt the comp. But the intake Temps when boosting so high with a JRSC with out a way of cooling it.
