1 - 8 of 8 Posts
and the search kept coming up zero results.
I want to make sure that I'm interpreting Hondata's website correctly that I can use the 02-04 Civic Si ECU for a swap. I was looking for a list of the ECU codes and what chassis they correspond with (ex. prb, prd etc.). I found an ECU but I don't want to buy it unless I can use it for a swap.
Yes you can... That is the PNF Ecu.. They are all over... They just dont support the reverse lockout feature...
while you're handy, it looks to me that the only ones you CAN'T use (USDM models) are:
05-06 Rsx (speed sensor is the issue right?)
05+ Element
05+ CRV
05+ TSX
for swaps..not in the original chassis.
05+ Element
05+ CRV
05+ TSX
Correct. the architecture of the board is different.
Still a good deal..
1 - 8 of 8 Posts
