can i use a crv block with a rsx type s. do i need to make any mods to the block or is just plug and play. i also have the type s tranny will it fit the crv block.
yes it is thanks 8)nikos said:Nothing.. Everything works and the trannies work too. Isn't honda something?![]()
We used to rev that high and when we took the engine apart it turned out there had been piston to valve contact. The car still made almost 300 hp with a JRSC. We also found excessive wear on the cylinder walls.nikos said:Someone told me that they have been revving it to 8200 with no problems....so far.....
But really, you are not going to be making power that high anyway... Just eb careful, that is all.
