1 - 13 of 13 Posts
FUCK IT
I Need KPRO for PRB, PPG synchro set, 1-2 or 1-4... Wheels for slicks and skinnies, Tial 44mm WG, Parachute, Window net, On/Off switch, Knuckles and brakes to mount DSS 5 hubs to, Nice set of cams, 4" muffler, 4" piping for exhaust, 4" thick intercooler good for 900hp, I have all of this to trade...
Broke right now and that's why I am trying to trade parts...
Parts for sale- I do not sell used and abused parts. Everything is either new or WORKS!
And I am not looking forward to trading unless I get your part first or have MANY vouches after what happened to me today... Of course it was on honda-tech..
http://hondamarketplace.com/showthread.php?t=2587298
K20a2 head. Just bought it from a friend that is parting out his motor. Head is in running condition. It is out of an '04 with 53k on it. Will come with valve cover, v-tec solenoid, cams, sensors. Will take pics is someone wants to see them.
$600
Type S throttle body, bought it with the head
$95 shipped, needs TPS and the plug for evap broke off when taking TB off :( .
EP3 Differential with bearings
$75 shipped
EBC Civic rotors, they are not drilled, only slotted.
These fit the small civic brakes 9". Not the 10" SI or integra brakes
NEW IN BOX.
$115 shipped
04 Type S k20a2 power steering pump
$65 shipped
04 Type S k20a2 AC compressor
$90 shipped
K20a2 waterpump housing (no water pump)
$40 shipped
ACL K20a2/K24 Main bearings, rod bearings, and thrust washers (not pictured but will be included)
Brand new in package. Cost me $130 and never used them
$120 shipped
K20a2 alternator
$100 shipped
k20a2 thermostat
$60 shipped
K20a2 knock sensor
$45 shipped
K20a2 belt tensioner
$40 shipped
Secondary o2 sensor off k20a2
$60 shipped
k20a2 crank pulley
$40 shipped
K20a2 waterneck for head
$25 shipped
k20a2 starter
$75 shipped
K20a2 intermediate shaft
$150 shipped
Shift linkage and box
$240 shipped
OBX 50mm silver BOV brand new never installed
$140 shipped
OEM k20a2 cat
$65 shipped
PRB intake manifold
$50 shipped
Stock k20a2 injectors
$50 shipped
K20a2 head. Installed Inline Pro springs and retainers. Comes with valve cover. Still on engine. Will pull off when paypal is received
$1100 shipped
Type S shifter box
$75 shipped
PRB ecu out of 02-04 type S
$300 shipped
K20a2 02-04 slave cylinder
$40 shipped
Stock Type S axles, 40k and perfect condition
$150 shipped
Stock k20a2 water pump with 40k
$40 shipped
k20a2 timing chain
$40 shipped
k20a2 timing chain guides
$30 shipped
k20a2 oil pump chain,gear,guide/tensioner
$100 shipped
k20a2 stock head bolts
$15 shipped
k20a2 stock pistons and rods with 80k
$60 shipped
k20a2 stock crank
$150 shipped
k20a2 windage tray
$20 shipped
K20a2 water port on front of head
$25 shipped
K20a2 thermostat and pipe
$60 shipped
K20a2 coil packs
$60 shipped
k20a2 engine mount
$20 shipped
k20a2 injector cover
$35 shipped
k20a2 stock fuel rail
$25 shipped
30x12x3" Intercooler with 3" outlets
Core is 24x12x3"
Bar and plate, has spot where a wastegate was rubbing but it doesn't leak.
$125 shipped
B-series Full Race ramhorn
T4 and coated with the hot temp coating
bung for EGT welded on (does not come with EGT probe in the picture)
$700 shipped or $850 shipped with wastegate and dumptube
B-series Skunk 2 adjustable cam gears (needs one screw in each one. I had to borrow it for another project, LOL)
$150 shipped
B-series obd2 alternator
$60 shipped
LS AC compressor
$60 shipped
3" AEM dryflow filter
$60 shipped
NEW Animal House Racing vacuum block
$30 shipped
Rear cargo cover for 94-00 integra
$75 shipped
Wiper motor assembly for 92-95 civic
$75 shipped
92-95 civic eg hatch headlights
$100 shipped
Integra LS cluster
$35 shipped
92-95 civic cluster
$20 shipped
Integra B-series VTEC head carbon fiber spark plug cover
$50 shipped
Integra LS 1999 Throttle body
Working sensors
$50 shipped
Hit me up and let me know what you want!
FUCK IT
Discussion Starter · #8 ·
I Need KPRO for PRB, PPG synchro set, 1-2 or 1-4... Wheels for slicks and skinnies, Tial 44mm WG, Parachute, Window net, On/Off switch, Knuckles and brakes to mount DSS 5.9 hubs to, Nice set of cams, 4" muffler, 4" piping for exhaust, 4" thick intercooler good for 900hp, I have all of this to trade...
sorry
1 - 13 of 13 Posts
