1 - 11 of 11 Posts
well,
i ve got an Euro EP3 with a JDM gearbox!
i ve got too a KPRO and there is a menu on Kmanager which alow making speedo correction with a RSX 05VSS!
what s the difference between it and mine VSS?
is it possible to replace it without no mods?
thanks
nope,
my VSS work fine!
but i think if a put a 05VSS,i will can correct my speedo with Kmanager?
am i right?
or i have to use a Yellow box just?
nope,
my VSS work fine!
am i right?
you are confused.
the purpose of the speedo correction is for those with '05+ transmissions. the 05+ tranny's VSS uses a complete different signal than regular pre 05's. if you dont convert it it reads like 1/50 (or is it 50 X) your actual speed. so it would be WAY off. K-pro has a fixed % it will multiply times the 05 VSS signal.
unless your tranny is newer (05+) tranny with the different VSS, you have nothing to worry about.
I am a little confused with this as well.
So you guys are saying the I can fix the speedo runnin my 04 rsx ecu with kpro adjusting the numbers given off by the vss on the 05+ trannies?
Sorry if it's a stupid question, just trying to understand.
Now I'm confused.
I have an 05 RSX-S. Can I run a 02-04 Base RSX 5 speed and have the speedo work? Are there any modifications that need to be done to make it work? Is there a link with this info out there already?
Now I'm confused.
its not that hard to understand. 05+ rsx have different VSS signals than 03-04
so no you cannot just swap a 04 base tranny & have the speedo work. You can buy a speedohealer & program it correct the signal for your cluster. K-pro will only correct for using 05+ VSS (when using 03-04 ECU) not the other way around
So basically i'm SOL until hybrid racing does their magic since I have 05 type S with an 02-04 base 5 speed .
1 - 11 of 11 Posts
