1 - 20 of 34 Posts
Hybrid Racing Now Available At CorSport
Hybrid Racing focuses on superior quality parts and support. We strive to provide the best in Honda and Acura performance parts. All of our parts have been engineered using the highest quality materials and cutting edge technology. New parts are constantly being prototyped and updated, so check back often for our newest releases.
CorSport USA.
Discussion Starter #5
Hybrid Racing - Available At CorSport
Hybrid Racing Available At CorSport
CorSport USA.
Discussion Starter #6
The kings of K, from the kings of honda online parts. A happy marriage.
Discussion Starter #7
02-05 Acura RSX Hybrid Racing Shifter Assembly
RSX Shifter Assembly by Hybrid Racing (2002-2005 Acura RSX)
**Pre-order Estimated Ship Date: Mar 21, 2013.**
Quick Overview
• MIND BLOWING PRECISE SHIFTS
• 10%-50% adjustable throw reduction
• 10%-50% adjustable gate spacing
• Adjustable shift knob height.
• Oil impregnated bronze bushings.
• 12 Months of grueling design, testing, redesign and more testing.
• 1,500,000 shifts on automated test rig.
• A6 Steel and 6061-T6 Aluminum Construction.
The performance of a shifter is everything. It can mean the difference between winning a race and missing a shift, and a high quality shifter can make your car shift like a new, high-performance machine. At Hybrid Racing, we take our shifters seriously. When we began designing our RSX shifter, we wanted to deliver a product that outperformed all others. We started our design process by incorporating the features that have made our other k-series shifters popular...adjustable height, adjustable shift knob position, and independently adjustable throw and gate spacing. We were the first to deliver features like this when we released our k-swap shifter over 5 years ago, and we have been refining our designs ever since. Our RSX shifter's performance is the best testament to this constant refinement.
We wanted to develop a shifter that felt great even after years of use and abuse. With that in mind, we incorporated a proprietary wear-compensating pivot ball design. We also used teflon-lined end links and spherical bearings to provide silky smooth short shifts and plenty of durability. To ensure everything worked as intended, we built a custom machine that cycled the shifter through all of the gears over 1.5 million times. To make sure we were leading the pack, we even put competing shifters on the same rig. No competing shifter lasted more than 10% as long as ours without seeing severe, performance hindering wear.
When it comes to adjustability, this RSX shifter truly shines. Adjustments are a breeze and can give you many different options in terms of shift feel. With just the turn of a single 5mm allen wrench, you can adjust your shift knob to be 2" taller or 1" lower than stock. With the same allen wrench, you can adjust the knob position, bringing it closer to or further from the steering wheel, meaning you can shift quickly and keep your hands on the wheel. Want your shifts a little shorter? This shifter can reduce throw anywhere from 10% to 50% (below stock throw) by just loosening the cable retaining bolt with a 10mm wrench and repositioning it. Gate spacing (left-right shifter motion) is also adjustable. This means that if you like short throws and wide gates, long throws and narrow gates, or any other combination, you can custom tailor it to your preference. The custom bell-crank style rocker design allows a larger adjustment range than competing shifters without putting your cables at risk of extreme angles, which is why many short throw adapters damage OEM cables.
A quick look at the materials used on our RSX shifter reveals a design that cuts no corners. The baseplate is made from formed and welded A6 steel with dimpled holes to improve rigidity. The rockers feature full 6061-T6 aluminum construction with oil-impregnated bronze bushings that are designed to provide quiet operation with no need for lubrication. The shift levers are made from stainless steel to avoid unsightly corrosion. Even the centering springs received special attention when we had them custom wound and installed inside of a rubber sleeve to cut down on noise during shifts.*
With its superior construction, adjustability, and unmatched testing and performance, this short shifter is second to none.
CorSport USA.
Discussion Starter #9
Hybrid Racing parts in stock and ready to ship to your front door!
Discussion Starter #11
02-05 Honda Civic Si Hybrid Racing Performance Shifter Cables
Hybrid Racing Performance Shifter Cables (K-Series 02-05 Civic Si EP3)
For several years, RSX and 8th Gen Civic owners have been raving about the benefits of our Performance Shifter Cables. Due to popular demand, we have now made the same great cables available to EP3 owners!
The Hybrid Racing shifter cables are a performance upgraded over the OEM shifter cables. The solid rod ends and bushings give the Hybrid Racing cables a firmer, tighter feel over OEM cables. Resulting in fewer missed shifts and a more connected feel to the chassis. In addition, the plastic swivel support tubes that are known to break on the OEM shifter cables have been replaced with stainless steel swivel support tubes, which are significantly harder to break and these cables are 30% thicker. We wanted to give people a peace of mind when they shift hard and during demanding racing applications.*
The Hybrid Racing shifter cables feature stainless steel push rods, swivel support tubes, and inner cables. The rod ends and mounting bushings are all 6061 aluminum that have received a T6 heat treatment and a black, hard anodized coating. All of this adds up to an amazing shifting experience.* *
Are these cables a direct replacement for my OEM EP3 Civic Si style cables?
The Hybrid Racing shifter cables are slightly thicker than OEM cables. It should be noted that the OEM cables have plastic twist-lock bushings on the shifter end. Hybrid Racing cables instead use spring clip and aluminum bushings. This aluminum bushings simplify installation a bit, but more importantly, they get rid of yet another plastic part that tends to flex on the OEM cables, which can often lead to a sloppy feeling shift. The extra spring clips that you will need to install the Hybrid Racing cables are included with the cables, so you will not need to buy any other parts. An easy to follow installation guide is available on our site.
What is included with these shifter cables?
Aside from 2 shifter cables, each shifter cable set includes 2 cotter pins, clips for the shifter end, and transmission selector lever springs (a $30 value for free).
Quick Overview
• Solid and Precise Shifts*
• Eliminate Miss Shifts & Gear Grinds
• Replaces Sloppy OEM 02-05 Civic Si EP3 shifter cables (K-series)
• Solid rod ends (no rubber like OEM cables)
• Billet aluminum bushings (no rubber like OEM cables)
• Stainless steel cables and cable guides
• High heat wrap & wire reinforced sleeve
• This is for a set of 2 cables, clips, transmission springs
CorSport USA.
Discussion Starter #14
02-06 Acura RSX Hybrid Racing Silicone Radiator Hoses (Ninja Black)
RSX and EP3 Silicone Radiator Hoses - Ninja Black
Are your radiator hoses cracking? Tired of a boring-looking engine bay with all those dull black hoses? Want something that’s easy to clean while still looking sexy? You’re in luck because Hybrid Racing has something for you!
These high-quality radiator hoses are the last you’ll ever need. Made with multi-layer fiberglass reinforcemed silicone and finished with a durable silicone outer layer, they’re pressure and temperature resistant from -165° to 350°F. We’ve also altered the upper hose geometry to provide an extra inch of clearance for your cold air intake, eliminating interference and keeping everything clean.
Speaking of clean, all you need is a little soapy water and a lint free rag to keep these hoses looking their sexiest.
Make your engine bay pop with Hybrid Racing’s silicone radiator hoses.
Kit includes:
• Upper radiator hose
• Lower radiator hose
Add the last bits of awesome with T-bolt clamps and oil cooler hoses! *
Quick Overview
• Four sexy colors: Ninja Black, Smoke Grey, JDM Purple, and Hybrid Green
• Replace those haggard, cracking rubber radiator hoses with pure sex
• Dress up your engine bay with durable, easy-to-clean silicone hoses
• Multi-layer fiberglass reinforcement finished with custom HR logos
Discussion Starter #17
Hybrid Racing K-Series Aluminum Fuel Rail - Black
Hybrid Racing Fuel Rail for Honda Base K-series
Quick Overview
• Universal K-series Engine Fuel Rail.
• Allows you to tuck your fuel lines with tucked fuel line kit.
• 1/8th npt port for fuel pressure gauge.
If you were wondering if there was any way to add more features to an after market fuel rail, the answer is a resounding “yes!” Our fuel rails are made from 6061 aluminum with T6 heat treatment. It can accept a -8AN fitting in the inlet(s) and outlet, and it features a durable anodized finish with a laser etched logo. Now for what makes our rail a little different…
We've included a 1/8" npt hole on our new fuel rails, that allows you to mount a fuel pressure gauge directly to your fuel rail. This puts the fuel pressure gauge in a spot that's easily visible, so you don't have to poke around in the engine bay just to see if you have fuel pressure.
The other detail on our fuel rail that should stand out is the option for plugging the side inlet and outlet and running the fuel to a centrally located -8AN fitting. This is positioned so that the fuel line can pass between the middle two cylinder intake runners. This is an excellent option for anyone looking to tuck their wires and lines.
What is included with the fuel rail?
Each fuel rail comes with (1) 1/8 NPT fitting, (2) -8AN/-6AN union, (2) -8AN plugs, and and 4 o-rings. This assortment of fittings will allow you run the fuel rail in almost any configuration possible.
What intake manifolds is this rail compatible with?
This rail has been shown to mount to the PRB, RBC, and RBB intake manifolds without needing any modifications. Any aftermarket intake manifolds that share the same fuel rail mounting points as the PRB, RBC, or RBB should also accept this rail.*
CorSport USA.
Discussion Starter #19
Hybrid Racing Honda/Acura Slim Oil Cap
Quick Overview
• Slim design for Increased valve cover to hood clearance.
• Designed to be easier to install and remove.
• Yes, these caps fit all D, B, H, F, J & K covers! :-D (All Honda and Acura chassis) *
At Hybrid Racing, we believe the recipe for a perfect part is the result of an elegant balance of form and function. When we set out to design this oil cap, we took inspiration from fuel doors used by the aerospace industry and started sketching.*
What we ended up with was a beautifully crafted oil cap that's both clean in appearance, providing improved valve cover to hood clearance, and super easy to remove.
Install this oil cap and know that you've purchased another Hybrid Racing product that is unmatched in quality and design.
Fits all Honda and Acuras!
Available anodized in your three favorite flavors and perfectly matching the Hybrid Racing Fuel Rails!
CorSport USA.
Discussion Starter #20
Honda/Acura Hybrid Racing V2 Performance Shift Knob - Black Delrin w/ Black Anodized Insert
Quick Overview
• Made in the USA.
• Heat resistant Delrin
• Durable anodized aluminum insert
• Weighs in @ 98g
• 10x1.5 Thread pitch with custom stainless lock nut.
Grabbing the gear lever in your car is a great feeling, except when your knob isn't comfortable. We wanted to develop a knob that was not only light weight and great looking, but also fit into the palm of your hand comfortably. A few models later, we chose the overall shape based off the best ergonomic design. The HRV2 Shift knob was designed and machined by HR in the USA, and constructed using Delrin and 6061 aluminum. We chose Delrin for its lightness and resistance to heat absorption, while maintaining the strength necessary for spirited driving.
CorSport USA.
1 - 20 of 34 Posts
