We don't have a release date yet but it’s not far away.
You will need to modify the rear cross member, remove the passenger side mount and remove the front mount.
As of now there will be no welding and you will not need to replace the front cross member. This may change for the actual production piece.
A few things that we noticed was that the alternator will need to be mounted lower and you will need to relocate the brake lines on the shock tower.
The clutch actuation has been resolved and as of now you will not be able to use the stock speedometer.
Here are a few picks of the hybrid racing CRX with a TSX engine. Remember this motor sits about 20mm higher than a 2.0L K motor.
We have since changed the angle of the motor slightly.
