1 - 20 of 72 Posts
All new Hybrid Racing AC/PS delete kit.
* Spring-loaded autotensioner
* replaceable gates pulley
* 6061-T6 construction
* stainless steel mounting hardware
* can be adjusted for various belt lengths within an approximate 2" range
If you're looking to gain some power by removing your car's AC and power steering, but don't want to lose the reliability and convenience of the factory belt tensioner, this is the kit for you.
This kit moves the alternator to the AC compressor's original location and features a spring-loaded, adjustable tensioning unit. The tensioner is designed to be able to be adjusted for belts within a 2" range meaning you have more options when you need a replacement belt. The tensioner has a tension indicator built in to help you insure your belt is properly tensioned.
Works with Honda and Acura K20 and K24 motors. For more information and pictures click HERE
MSRP: $249.99
Availability: In Stock
1 - 20 of 72 Posts
