1 - 20 of 37 Posts
Find HPS Parts for your car here
HPS All Cars Category
Click here to see these products in our catalog and check out the most current pricing.
HPS High Temp Reinforced Silicone Hoses
HPS Silicone Hose features 4-ply reinforced high temperature material, for which meet or exceed SAEJ20 Standard. HPS Silicon Hoses are used by professionals in industries such as high performance racing vehicles, commercial truck and bus, Marine, agricultural and off highway vehicles, turbo diesel, food and beverage, and general manufacturing industries.
HPS silicone hoses are available in straight coupler, 1 ft tube, 3 ft tube, Charge Air Cooler Hose (CAC), hump coupler, reducer coupler hose, 45 Degree Elbow Coupler and 45 Degree Elbow Reducer, 90 Degree Elbow Coupling and 90 Degree Reducing Elbow. HPS also carry the performance silicone vacuum hoses as well. HPS silicon hoses are available in both standard inches and hard-to-find Metric sizes. In order to meet the high demand and shorten the turnaround time, up to 90% of HPS silicone hoses are instock and ready to ship or pickup from HPS store.
Features
HPS silicone hoses are made of 4-ply reinforced and knitted premium polyester fabric with high temperature silicone rubber, engineered for extreme temperature and various pressure ranges where high performance levels are required.
Technical Specification
Temperature Range:- 65 deg. F to + 350 deg. F (177 deg. C)
Color: Black / Blue
Reinforced Layer: 4-ply
CorSport USA.
Discussion Starter #5
02-06 Acura RSX Base K20A3 HPS Shortram Air Intake (Wrinkle Black)
HPS Performance Shortram Air Intake
HPS short ram intake systems are an economical alternative to our cold air systems and deliver performance, value and ease of installation. HPS short ram intakes are easy to install under the hood and cost less compared to the cold air intake systems. During the development process, we found certain applications respond favorably to shorter inlet lengths over our longer cold air designs. For these applications, we offer a short ram system only. With HPS in house dyno, we are able to locate the filter in the coolest area of the engine compartment to deliver the best performance of the shortram air intake systems.
Key Features:
-Mandrel-Bent 6061 T6 Aluminum Alloy Piping
-HPS Race Proven Silicone Hoses and T-Bolt Clamps
-CNC Machined Mass Air Sensor Fittings
-TIG Welded Mounting Brackets
-K&N High Flow Performance Air Filter
-Air Filter Heat Shield
Product Specifications:
-Dyno Proven Performance Gains: +6.0 Whp, +4.1 Ft/lbs
-Color: Wrinkle Black
-CARB Exempt: No
-System Type: Shortram air intake system
HPS Performance Shortram Air Intakes are Designated as Racing, Off-Road or Show Use only
Vehicle Application:
2006 Acura RSX Base 2.0L (K20A3)
2005 Acura RSX Base 2.0L (K20A3)
2004 Acura RSX Base 2.0L (K20A3)
2003 Acura RSX Base 2.0L (K20A3)
2002 Acura RSX Base 2.0L (K20A3)
CorSport USA.
Discussion Starter #7
02-05 Civic Si HPS Shortram Air Intake (Red)
Key Features:
-Dyno Proven Performance Gains: +10.2 Whp, +7.0 Ft/lbs
-Color: Red
-CARB Exempt: No
CorSport USA.
Discussion Starter #12
02-05 Civic Si HPS Shortram Air Intake (Wrinkle Black)
Key Features:
-Color: Wrinkle Black ( * Also available in Polish & Limited Gold)
-CARB Exempt: No
2005 Honda Civic Si 2.0L
2004 Honda Civic Si 2.0L
2003 Honda Civic Si 2.0L
2002 Honda Civic Si 2.0L
CorSport USA.
Discussion Starter #14
2002-2006 Acura RSX HPS Silicone Radiator Hoses Kit (BLUE)
PS High Temperature Reinforced Performance Silicone Radiator Hoses Kit
The HPS Radiator hose kits are designed to replace OEM rubber hoses. This hose kit can be used for both motorsports and daily driving use. HPS Radiator hoses are made from multi-ply premium grade silicone and reinforced with high-quality polyester for which reduces the risk of component failure and enables higher temperature and pressure to be maintained with complete confidence.
Technical Specifications
3-Ply Reinforced
Silicone hose is NOT compatible with fuel or oil.
CorSport USA.
Discussion Starter #18
02-06 Acura RSX Base K20A3 HPS Shortram Air Intake (Blue)
Key Features:
-Color: Blue
-CARB Exempt: No
CorSport USA.
1 - 20 of 37 Posts
