1 - 18 of 18 Posts
What you need:
a2/z1 water pump
a2/z1 oil cooler
associated hoses
joint cooler from s2000
part # 11107-pt2-000 ~$5.00
1. Remove plug.
CIMG0639 by cjk_142001, on Flickr
Install s2000 joint cooler as seen below.
2. install a2 or z1 oil cooler and filter.
CIMG0661 by cjk_142001, on Flickr
3. install a2 or z1 water pump
CIMG0660 by cjk_142001, on Flickr
4. Install misc hoses
5. Karcepts ac/ps removal pulley kit :up:
CIMG0659 by cjk_142001, on Flickr
ENJOY!
Discussion Starter · #10 ·
hmmm,darn.what's the reason for using the A2 water pump on K24's?I'm already going to add the oil cooler to my K24,just wondering if it's worthwhile to switch water pumps and for what reason.
you could just do an external cooler, but oem is oem. Only reason I did it. Keeping it clean.
Discussion Starter · #77 ·
trying to do a k20a2 head with a k241/4 block. if i do the s2000 swap oil cooler joint i can use my k20 water pump etc etc....... my question is. does that mean i HAVE to tap in for oil squirters? or can i run the block without oil squirters on stock internals????
you don't need oil squirters.
1 - 18 of 18 Posts
