really, my motor could blow from that??I would just fix it. No point risking your motor blowing.
What did you use to tighten the bolt?
i'll see if i could do that. in the mean i'll try to take some pics so u guys can have a clear view of it.take the pan back off and see if u can get the stud with a vice grip
The bolts are only supposed to be torqued to 8.6lbs, take the pan off and try to remove the broken bolt...i'll see if i could do that. in the mean i'll try to take some pics so u guys can have a clear view of it.
