The AC lines were a matter of figuring out which lines to start with...I used the 03 Accord compressor lines and had the fittings cut off to use a thicker wall hose. The stock 03 hoses are thin and kinked too easily. Spacing the fan forward was the next task so I used an aftermarket thinner fan and trimmed the stock fan bracket (which supports the AC condensor) to fit. It's not too pretty but it works and clears the hoses. I may trim it a bit better before I charge up the system.
I did magage to use the stock suction line from the firewall (the thin one) and snaked it around the new engine mount to a flex piece, then into the new receiver. The receiver is now in the hole on the passenger side frame rail.
I also decided to use the pressure switch in the receiver instead of the factory one on the condensor, mainly to make it cleaner.
I still need to make lower mounts for the condensor, but Hasport will be making a new lower support bar for the production kits and I'll probably wait for that...
