1 - 5 of 5 Posts
Just wondering, i bought a SSR 4-1 header about 2 years ago for my stock k20a2.... Now im planning on going k24 in the near future. 12:1'ish comp., stock A2 head, decent cams, mabye run e85, blah blah...
So how would my shelf SSR k20 header do against lets say a custom SSR for my specific set-up??? Hopefully not too bad since it isnt an extreme k24 build, maybe SSR can chime in... :rolleyes:
I would think you would be fine, since you're using stock ported head. I've seen setup like yours and use rcrew header and put up good numbers.
Infinite levels to this..
x2 SSR doesn't make cheap shelf headers anyway. all their headers are top notch. your header would work fine with your new setup. :up::up:
would the k20 header fit clearance wise? the k24 is bit taller
1 - 5 of 5 Posts
