1 - 4 of 4 Posts
how much clearance the k24a4 piston and valves have before p2v contact?
anyone know how much clearance the k24a4 piston and valves have before p2v contact?
I am looking to do some BC stage 3 cams and was looking it up. I know stage 3 are smaller then stock tsx. I listed the specs below. I plan to keep factory redline for now until I can do swap out the piston and rods with something better down the line. Will this set up work?
bc stage 3 specs
Adv. Dur. Dur @ .050 Lift (in) Lift (mm)
296°/284° 206°/193° .429"/.410" 10.89/10.41
tsx stock cams spec
310°/302° 210°/212° .451"/.453" 11.45/11.50
rsx stock cam spec
302°/305° 219°/215° .483"/.431" 12.27/10.95
kool thanks if that is the case. then the stage 3 for k20a3/k24a1 should work since its cams lift are smaller then the TSX and RSX cams
1 - 4 of 4 Posts
