1 - 12 of 12 Posts
just curiouse what type or tranny oil you guys are using and how quarts it takes to fill it up . i would like what the book says if you have the info.
also anyone experiencing the second gear grinding ???
2 quarts are needed for the trans. I'm running GM Syncromesh friction modified. Use to have a Problem with third gear in the morning, Not anymore after i use the synchromesh. Mines is also a 02 type s trans without the recall done on it.
I used around 2 quarts of redline MTL in my rsx tranny.My Rsx is an 03 and it would grind sometimes also.I changed the fluid and i never heard a noise or grind from it again :up:
Discussion Starter · #7 ·
my grinding isn't that bad if i put it into gear before 2500 in second there is no problem but after that i woiuld have to shift it few sec. slower than all the other gears.
so gm sycromesh works good ? is that better or redline mtl?? thanks for the feedback
I never used the GM syncromesh but i can vouch for the redline MTL.The tranny shifted and engaged alot smoother then over the stock fluid.I changed the fluid around 10,000 and after 20,000 miles i havent had a noise or grind ever since :up: I can rip my gearbox without having to worry about it grinding hehe :up:
Discussion Starter · #9 ·
i really haven't tried to shift my car from first to 2nd after vtec point i guess i'm just scared to mess it up so i haven't tried how it engaged in vtec mode; but the other gears seem to work good after the car is warmed up. and yea my second is lil hard to get in at night. when its cold somtime i have to double clutch get it in or let rpm drop all the way then put it in gear.
i think i will try redline mtl ,any online place to buy you know of??
1 - 12 of 12 Posts
