1 - 9 of 9 Posts
I am trying to locate what I have dismantle from my block and I know I should have put it in a safer place but I think I am missing a key to the crankshaft. The crankshaft sprocket that drives the oil pump and the cams picture number 12. Is there a key for that?
Also is there a key for the crankpulley? There must be two keys because I can see the indentation for the crankshaft sprocket and the obvious the crankpulley key. The parts store only have one key which is number 16 in picture. Part number for the two keys? Help??!?!? :confused:
The sprocket itself has no key. there a little dimple inside the sprocket that lines up with the opening in the crank. There is only one key and that is to keep the crank pulley liked up. I thought I lost my key to so I ordered two new ones from honda.
.....There is only one key and that is to keep the crank pulley liked up.....
That's right..... Only 1 key.. Everything else slides into place with the groves that are built in...
Banned
look in the back of the crank gear (sproket) you will see a little insert that it attached to it... slide that in the crank to secure the gear... It can only go one way..
There is only one key that keeps the crank pulley with the crank
Discussion Starter · #9 ·
i will take a picture of the sprocket, dont have one on hand, but this picture show the notch i was talking about. Took this picture off of a member here, hope u dont mind.
The back of the sprocket does not have any key other then a drilled hole.....so am i missing a key?
1 - 9 of 9 Posts
