1 - 3 of 3 Posts
Well i fiited my RBC today,
Thought it was sitting a bit high but i closed the hood slowly,
It seems to be hitting one of the sensors on the TB when i close it,
It will close but it takes a bit of pressure to do so,
Anyone else have this problem with theres??
Im using hassport mounts??
should be the little vacuum nipple that goes to the brake booster. you can cut your hood slightly, try bending it so it raise up that high or relocate it. i believe theres a company making the throttle body adapter with an open port to run that line.
u have to bend down the brake booster fitting a bit, and also trim out the webbing of the hood in that area
1 - 3 of 3 Posts
