1 - 17 of 17 Posts
I have a '02 Ep3 Type-R. My problem is very disgusting. In K-Manager Cam and Camcmd stuck at "0" and never changes. So we couldn't change the map properly. We couldn't find the problem.
There are no DTCs. What about Cam? It is always "0" anyway. We changed the places of two camshaft sensors and then there comes two errors. Cam stucks at "107" and CamCmd is still "0".
You should have DTCs if the ECU is detecting the sensor and the command. Either the sensor is disabled, like the tune is set to disable CAMCMD (open loop?), or you have another (wiring) problem and the electrical sense to the ecu on a pin is wrong.
1 - 17 of 17 Posts
